LabWindows/CVI
Issue with digital input read raw acquisition
I have an issue with digital acquisition I am using the DAQmxReadRaw function and change detection mode, When I try to test my acquisition using a 5volts power suplly all leds indicators connected to this raw turn red (0 value) instead of turning green only the input I passed the 5volts onto.
Here the the code used to make this acquisition:
main file
int32 CVICALLBACK DigitalInputsAcquisition(TaskHandle taskHandle, int32 signalID, void *callbackData)
    int PowerFailureByte;
    int EngineFailureByte;
    int TemperatureFailureByte;
    int BrakeResistorFailureByte;
    int OilLevelHighByte;
    int OilLevelLowByte;
    double OilTankVal=0;
    //DAQmxReadDigitalU16(DigitalInputsTask, DigitalSamplesPerChan, 10, DAQmx_Val_GroupByChannel, DigitalInputsArray, 8,  &SamplesPerChannelRead, 0);
    DAQmxReadRaw(DigitalInputsTask, DigitalSamplesPerChan, 10, DigitalInputsArray, 8, &DigitalSamplesPerChan, &BytesPerSamples, 0);
    //DAQmxReadDigitalLines(DigitalInputsTask, -1, 10, DAQmx_Val_GroupByScanNumber, DigitalInputsArray, 8, &DigitalSamplesPerChan, &BytesPerSamples, 0);
    PowerFailureByte =  DigitalInputsArray[0];
    EngineFailureByte =  DigitalInputsArray[1];
    TemperatureFailureByte = DigitalInputsArray[2];
    BrakeResistorFailureByte = DigitalInputsArray[3];
    OilLevelHighByte = DigitalInputsArray[4];
    OilLevelLowByte = DigitalInputsArray[5];
    SetCtrlVal(dvdxt, DVDXT_Tension_LED,PowerFailureByte);
    SetCtrlVal(dvdxt, DVDXT_Moteur_LED,EngineFailureByte);
    SetCtrlVal(dvdxt, DVDXT_Temperature_LED,TemperatureFailureByte);
    SetCtrlVal(dvdxt, DVDXT_Resistance_LED,BrakeResistorFailureByte);
    SetCtrlVal(dvdxt, DVDXT_Oil_LED,OilLevelLowByte);
    if(OilLevelHighByte==1)
        OilTankVal= 50;
    else if (OilLevelLowByte==1) OilTankVal = 25;
    SetCtrlVal(dvdxt, DVDXT_Tank_Oil_Level, OilTankVal);
    return 0;
digitalIO.c file
#include <NIDAQmx.h>
TaskHandle DigitalInputsTask;
//Digital inputs task
int32 DigitalInputsAcquisition(TaskHandle taskHandle, int32 signalID, void *callbackData);
void CVICALLBACK AcquireDigitalInputs(TaskHandle taskHandle)
    DAQmxLoadTask("DigitalInputs", &DigitalInputsTask);
    DAQmxRegisterSignalEvent(DigitalInputsTask, DAQmx_Val_ChangeDetectionEvent, 0, DigitalInputsAcquisition, 0);
    DAQmxStartTask(DigitalInputsTask);
    return ;
May I use another acquisition function , to get digital inputs one by one?
any suggestions?
Olivier
(3,054 Views)
I didn't see anything wrong in your code.
Could you try updating the LabWindows/CVI Runtime Engine and your DAQmx drivers ?
(3,012 Views)
