LabWindows/CVI
Is there a way into MAX2.1 from CVI?
I'm sure there must be, but I can't find the Data Neighborhood anywhere.
(3,620 Views)
What are you trying to do? The channels configured in the Data Neighborhood are supported by the Easy I/O library functions, but not by the low-level Data Acquisition library. You can use the channel names in the Easy I/O functions for the channel string. Are you wanting to programmatically retrieve some information from MAX?
Best Regards,
Chris Matthews
(3,620 Views)
Hi Chris - thanks for the quick response. The idea was to retrieve the channel names and scales from MAX to set graphs up accordingly.
(3,620 Views)
Your in luck. I have a utility DLL I put together for just this thing. I attached it to this e-mail with the header file. There are some functions to retrieve the values of a custom scale, and some functions to retrieve the channel names. See the header file for instructions on using the functions.
Best Regards,
Chris Matthews
(3,620 Views)
"Chris Matthews" wrote in message
news:5065000000050000003E500000-1005954886000@exchange.ni.com...
> Best Regards,
> Chris Matthews
> National Instruments
(3,620 Views)
Chris
I noticed your utility DLL is calling a DLL called Nicfq32.dll which has a
lot more useful functions in it I could use. Are the functions in
NIcfg32.dll documented anywhere or is there a H file somewhere.
John
> Best Regards,
> Chris Matthews
(3,620 Views)
Not yet. We are working a programmer's API for MAX, but it isn't shipping yet. The functions that you see there are for our internal driver teams use. If there is something specific you are trying to do, let me know what it is and I'll make sure our MAX team knows about it.
Best Regards,
Chris Matthews
(3,620 Views)
