LabWindows/CVI
Is there a simple way to save raw data as a BMP, JPEG & TIFF in LabWindows ver 5.0
I am using a Spot RT camera that stores image data into a buffer. I would like to save this data as a BMP, TIFF and JPEG. I need simple way to understand this process. Please help me.
(3,692 Views)
There is a set of functions in CVI that allow you to work with bitmap data and files in the User Interface Library>>Bitmaps function group.
The NewBitmap function allows you to take raw data and create a bitmap resource that can be manipulated programmatically, assuming that you pass it the data correctly.
After that you can use the ClipboardPutBitmap function to place the bitmap somewhere so that it can be manipulated outside of your application, however it doesn't appear that you will be able to save it directly to a file with this group of functions. Although, it is probably significantly easier to use them than writing binary data to a file, which would be your only other option.
Jason Foster
www.ni.com/ask
(3,692 Views)
Jason,
Thank you for the response, but what about the JPEG and the TIFF format. They are actually more important.
Vision Boy
(3,692 Views)
