LabWindows/CVI
Is it posssible to write a new line ("\n") to an INI file?
(4,410 Views)
If you are using the inifile.fp tool that comes with CVI, no, there isn't a built-in way with these functions to add new lines to the file. You could either do this in post processing of the file with the normal CVI File I/O functions, or you could edit the inifile.fp tool (the source code is provided for you) to add functionality to it to add new lines.
Best Regards,
Chris Matthews
(4,410 Views)
Yes, use the Ini_PutRawString function.
(4,410 Views)
