LabWindows/CVI
Intercepting a windows application message?
I am trying to intercept an access violation message from a third party DLL.  The purpose is to intercept this message and programmatically post the OK message to destroy its popup window.  I am trying to get an example program running which traps for the WM_CLOSE message ID.  My callback is never processed when I hit a close button (X on the title bar).  Any ideas?
int main (int argc, char *argv[])
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1; // out of memory
 if ((panelHandle = LoadPanel (0, "FindErrorMessage.uir", PANEL)) < 0)
  return -1;
 DisplayPanel (panelHandle);
 /* To intercept the WM_CLOSE message with MyCallback */
 status = InstallWinMsgCallback (panelHandle, WM_CLOSE, MyCallback, VAL_MODE_INTERCEPT, NULL, &postHandle);
 RunUserInterface ();
 DiscardPanel (panelHandle);
 /* Uninstall the event handler and free associated memory */
 RemoveWinMsgCallback (panelHandle, WM_CLOSE);
 return 0;
int CVICALLBACK MyCallback (int panelHandle, int message, unsigned int* wParam, unsigned int* lParam, void* callbackData) {
 //to do items here
 MessagePopup ("test 2","test 2");
return 0;
(3,953 Views)
This thread might have some useful information for you:
http://forums.ni.com/ni/board/message?board.id=180&thread.id=14973&view=by_date_ascending&page=1
They approach doing what you are trying to do a few different ways, so one of their solutions may work for you.  Let me know if none of those can work for you.
Kristen
(3,920 Views)
All,
Thanks for the link to the previous posts related to this subject.  On the advice of a colleague, I used a tool called Spy++ to query the ID # and text of the application error popup window.  Then using calls from within CVI to the Windows SDK I was able to obtain a handle to that particular popup and post a message to close it programmatically.  The very simple code snippet is below.  Note:  In my case I knew exactly when the application error message would pop up so I was able to trap for it at a specific point in time.
HWND hwnd
//obtain the handle of a window with the ID "#32770" and text which includes "my text"
hwnd = FindWindow ("#32770", "my text)
if (hwnd) {
       //send a WM_CLOSE to the handle found above
       PostMessage (hwnd, WM_CLOSE, 0, 0);
       break;
Message Edited by mulhall on 02-19-2008 12:53 PM
(3,900 Views)
