LabWindows/CVI
Interactive Execution surprise
looking at the question posted here I came across some strange behaviour of the Interactive Execution window...
I entered the following code (you have to start somewhere, this is for the definition of NULL) and ran it
#include <ansi_c.h>
The Debug Output windows says:
SXS: RtlQueryInformationActivationContext() - Caller asked to use activation context from hmodule but passed NULL
Message 1 of 14
(5,795 Views)
I can add that I could reproduce this behavior on my computer running Windows XP, i.e. restarting CVI, opening a new Interactive Execution window...led to the same result.
However, I could not reproduce it on my other computer, running Win7.
Message 2 of 14
(5,777 Views)
I see no errors or warnings nor any message to debug output window on my CVI2009 SP1 on Win7
Message 3 of 14
(5,773 Views)
Thank you, Roberto, for looking into it!
So we agree that this is not a problem on Win7 - but it still happens on my XP computer...Smiley Frustrated I have checked that on both systems the file is the same (located in the CVI2012\include folder)
Message 4 of 14
(5,770 Views)
Hi Wolfgang,
can you please add an Example file and a short description what to do with what file, so I can test it here with CVI2012 on a XP computer and try to reproduce this behaviour.
Abduelkerim
Sales
NI Germany
Message 5 of 14
(5,768 Views)
Hi ADagli,
the description is quite simple...
  1. Open the Interactive Execution window (Window / Interactive Execution)
  2. Enter or paste: #include <ansi_c.h>
  3. Click the green run button
Thanks!
May be the debug message I receive may also give a hint... for me, however, it is not meaningful
Message 6 of 14
(5,763 Views)
I tend to think that something is wrong with this computer...
My new discoveries:
1) the same problem appears for any #include in the Interactive Execution window
2) The function RtlQueryInformationActivationContext() listed in the debug window belongs to ntdll.dll
3) In general, the Interactive Execution window is working properly. For example:
typing
printf ( "Hello world" );
results in the CVI popup message:
"The following include statement are needed in the Interactive Execution window:
#include <ansi_c.h>
Do you want to add them?
Pushing the 'Yes' button results in the code
#include <ansi_c.h>
Running it gives both the 'Hello world" text AND the build output mentioned earlier...
Message 7 of 14
(5,756 Views)
Hi Wolfgang,
thank you for your post.
I could reproduce this behaviour.It does nor seem to be an error, but what it means is not clear for me.
I will forward this to our R&D department. As soon as I have an answer I will post it here.
Abduelkerim
Sales
NI Germany
Message 8 of 14
(5,750 Views)
Wow,
thanks! Actually I didn't expect this to be reproducible, to me it appeared so peculiar. Puh, I am relieved that it is not my bad mistake...
Message 9 of 14
(5,746 Views)
although this is not an urgent topic I tend to forget about things less pressing Smiley Wink So is there any news available allowing me to personally 'close' this case (e.g. accept it as strange but expected behavior, categorize it as bug...) ? Thanks.
Message 10 of 14
(5,651 Views)
