LabWindows/CVI
Instrument I/O Assistant Task with Device Driver
Hello All,
I got some messag pop-up hint while using Tools»Create Instrument I/O Task in Labwindow/CVI.
=> "The feature requires the Instrument I/O Assistant.
=> Please install the Instrument I/O Assistant from the NI Device Drivers CD..
I want to practive to create Instrument I/O Task.
Is there any download entry on NI's web site for this?
Much thanks,
nonomiya
(3,400 Views)
Hi Nonomiya,
You simply need to install the Instrument I/O assistant from the device driver CD that ships with CVI. It should allow you to use these tasks. As far as something that will act like the assistant and let you create those tasks in CVI without actually installing the Instrument I/O Assistant from the device driver CD, there's not much available.
Hope this is helpful,
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,382 Views)
Hi Matt,
I am using the evaluation 7 days labwindows and we are still thinking to buy labview or labwindows/cvi.
Now I am trying to record from NI 6259 board to CVI. but I have the same problem here with I/O assistant. Is it possible I can install I/O in the valuation versio?
Jingjing
(2,982 Views)
