LabWindows/CVI
Install on xp
I am using LabWindows/CVI 8.1 (full developer) on windows XP. I installed it as an administrator and all works well, But when I try to run CVI as a user account with limited privilages, it get an "This utility could not open registry entries for the given CVI version" error (and a bunch of not found errors)
The installer did not ask me the typical windows install question: "is this install  for the current user only or everyone".  I'm trying to roll out this application and need a solution ASAP.
Anyone else having problems like this?
I'm also using TestStand 4.0 for this system - don't know if I will have problems with this also
Don
(3,445 Views)
Hi Don,
See the KB entitled Receiving a Change Compatibility Mode Registry Error When Launching LabWindows/CVI.
Best Regards,
Jonathan N.
(3,431 Views)
Thanks, that did the trick for Labwindows/CVI. Are you any good with TestStand ? I'm having problems with that as a non-admin also:
http://forums.ni.com/ni/board/message?board.id=330&message.id=16606
Don
(3,418 Views)
