LabWindows/CVI
Insert/Overwrite Mode in Text Boxes
I am using a simple textbox with CVI 5.5 and I am unable to switch between Insert and Overwrite mode while editing the text. Is there any way to switch between these modes other than the "Insert" key which doesn't work? TIA!
(3,566 Views)
A simple workaround should be to select with mouse or keyboard the part of text you need to replace and simply retype new text; this isn't the exact behaviour as overtyping but it works.
Roberto
(3,566 Views)
Keith:
The Textbox control has no native support for insert mode. In order to get this effect, you'd need to write some code to handle the EVENT_KEYPRESS event of the Textbox, and remove a character from the Textbox if the user presses any printable character.
Chris Wood
(3,566 Views)
