LabWindows/CVI
In my project UIR i have one table %2Ctwo normal graphs and one bar graph %2C while report generating in word document everything is coming but bar graph is also coming but its values are not coming . can know how to do that in labwindow%2FCVI%3F
In my project UIR i have one table ,two normal graphs and one bar graph , while report generating in word document everything is coming but bar graph is also coming but its values are not coming . can i know how to do that in labwindow/CVI?
(3,714 Views)
How do I post a message?
In the first field, the Subject field, type a title for your message.
  1. This is the only part of the message that shows up on the message listing page, so try to make it something that will be clear and concise. Use keywords about your topic.
  2. In the second field, the Body field, type your message. Put details about your topic here. Use the WYSIWYG (What You See Is What You Get) Editor to format your post for easier reading. If you are posting on a technical topic, it is helpful to include all pertinent information regarding your inquiry in the body.
  3. Click Check Spelling to look for misspelled words, or you can click Preview Post to see what your post will look like on the boards.
  4. When you are happy with your message, click the Submit Post button.
(3,711 Views)
Good suggestion from Wolfgang.
Another suggestion from me would be : say a little "thank you" when people help you fixing your problems. That's just politeness and maybe it will encourage people to help you another time when you need it. (This suggestion is made after I noticed in some previous posts that it was not obvious for you to say "thank's")
(3,704 Views)
Another additional suggestion:
Do not open more threads on the very same argument! (see here)
(3,698 Views)
My suggestion had a negative exit: a new thread has born! Smiley Frustrated
Discussion follows here.
(3,679 Views)
