LabWindows/CVI
IVI Scope continuous acquisition
Hi All,
I have been using CVI for a long time but for the first time I am approaching the interaction with an oscilloscope.
After several tests, I decided to use the IVI libraries
Until now I managed to acquire a signal and view it (1 shot)
Reading the guides, I understand that it is possible to grab a continuous signal (between the start and stop pressure).
Unfortunately I can't find the right sequence of APIs to do it.
In practice, I would like to acquire everything that passes from the scope and then analyze it offline
Currently I can capture a single waveform (like pressing the "single" button on my oscilloscope)
Can someone help me or tell me where to find an example to do this?
(2,822 Views)
Hi Requiem_Q,
Can you post the code for what you are doing already? That may help to get a better idea of modifications we can make to get you where you need.
LabWindows/CVI also comes with an IVI Scope example, which you can locate in the Example Finder, if you are not working from this already, so this may be a good place to start.
Best,
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(2,733 Views)
So far I've used a standard sequence
1) get scope handle
2) enable ch1
3) set ch1
4) set trigger
5) set acquisition
6) get signal
so, my application works like the "single" button on the oscilloscope
What I would like to do is simulate the "Run" button
I think I need to change point 6 (or points 5 and 6)
I also thought about making a thread and repeatedly pressing single but it doesn't seem very elegant to me.
(2,716 Views)
Hello
first of all you can NOT actually capture continues data on "regular" scope because it memory limitation.
you have 2 possible solutions:
1.use a segmented memory scope that can store between 1k-2k waveforms.
2.use one of NI PXIe scopes & use one of NI scope samples to do continues sampling.
good luck
Daniel
(2,699 Views)
If I understand both solutions require dedicated hardware, right?
thanks
(2,691 Views)
yes
(2,688 Views)
