LabWindows/CVI
I want to use variable in Filename.
static char label ;
GetLabelFromIndex (panel, PANEL_LISTBOX, value, label) ;
DisplayImageFile (panelHandle, PANEL_2_PICTURE, label) ; // file not found..
How can i add .jpg in label?
Message Edited by -Juha- on 06-16-2006 03:53 AM
(3,190 Views)
you could use the formatting function: Fmt (label, "%s[a]<.jpg"). The [a] format modifier stands for 'append', as described in the Formatting help files.
(3,185 Views)
Much simpler:
strcat (label, ".jpg");
(3,179 Views)
However, you'll probably want label to be an array of char rather than a single char.
Martin
Certified CVI Developer
(3,168 Views)
