LabWindows/CVI
I'm looking for a CVI driver for the PICA93LV I2C adapter from CALIBRE_UK
I need a simple C driver for the PICA93LV interface.
The driver provided by CALIBRE_UK don't work (Linking errors, the functions prototypes are not known).
I use NT 4.0 and CVI 5.0
Thank you for any help.
(2,899 Views)
You could find a LV/CVI driver for this instrument at http://www.ni.com/devzone/idnet/default.htm . If it's not listed there, it leaves you with one of a couple options. First, I would like you to submit a request for this driver at: http://zone.ni.com/idnet97.nsf/instrumentdriverrequest/
We develop drivers based on demand and popularity so the more requests we have for it, the greater the possibility that we will develop one.
If you would like to try developing your own instrument driver (or modify the existing one), we have documentation, model instrument drivers, and driver templates to help at :
http://www.ni.com/devzone/idnet/development.htm
We also have a syndicate of third party vendors that specialize in National Instruments' products and services. Some
of the vendors specialize in driver development. I would suggest contacting one of the Alliance members at:
http://www.ni.com/alliance
An instrument driver is a collection of functions that implement the commands necessary to perform the instrument�s operations. In short, someone read the instrument user manual and implemented some of the functionality in a program for the end user. Instrument drivers are not necessary to use your instrument. They are merely time savers to help you develop your project so you do not need to study the manual before writing a program. With all of this work already done for you in the driver, instrument drivers can significantly reduce development time.
There are examples in LV/CVI on Instrument Connectivity. I would suggest tweaking them to suit your application. Also the specific command that your instrument responds to can be found from it's manual.
Some useful resources for your application are
ni.com > NI Developer Zone > Development
Library > Instrument Connectivity
http://search.ni.com/?col=alldocs&layout=TechResources&ql=a , to search examples and knowledge bases
Hope this helps.
(2,899 Views)
Bonjour,
I have got the solution by recreating the .lib file
with the CVI menus ;
Opening the .h file in a window. In the "options" menu ,
select Generate DDL import library. choose the .dll file.
So we get the new .lib file which is OK with CVI.
(2,899 Views)
