LabWindows/CVI
I have bought Pixelfly camera from PCO with sdk software included Pccam.h. Pccam.lib
and PCCAM.dll. for windows 2000
I use Labwindows CVI 5.0 and windows2000 . When I inclued the files into my
project (Pccam.h and Pccam.lib ) correctly and I put in directory of my project
PCCAM.dll and i Build project I have link error :
Bad header encountered while reading external module: 'PCCAM.dll
I hope you can help me!
Donnadei Eric
(3,747 Views)
Hi Eric -
I have seen this error before - usually the dll has been created with VC++ 6.0 and CVI 5.0 does not understand the new 6.0 import library format. You have several options:
1. get CVI 5.5.1 - it understands both VC++ 5.0 & 6.0 import formats
2. if you have the source code for the dll,
add the 5.0 link option to your VC++ projecy by
A. Go to Project >> Settings >> Link Tab.
B. In the link options box type /LINK50COMPAT
3. Alternatively, use CVI to open a header file that prototypes all of the functions exported from the DLL, and then select CVI's Options >> Generate DLL Import Library to generate a *.lib file that you can successfully link in your project.
This information is alos available on our external help site, www.ni.com/support, search for "Bad h
eader encountered" or Document ID 1DNEQDNU.
good luck
ben schulte
national instruments
(3,747 Views)
