LabWindows/CVI
I cannot set TDS3034B/TDS3054B Trig Mode to "AUTO"?
I'm working on an ATE project with CVI 7.1. When I want to do  "voltage peak-peak value "measurement the DPO(TDS3054B) is always in trigger "NORMAL"  mode waiting for being triggered.But I don't like that I just need it in "Auto(Untriggered Roll " mode and then I can get the right data. Anybody can help me?
In fact,the problem is I can't find the function in the Driver(for TDS 3000 series DPO with LabWindows) to realize the setting.
The codes are as follows:
void ConnectToDPO(void)
 ViSession DPOHandle;
 ViReal64  Vpp;
 ViUInt32 pHandle;
 pHandle=(ViUInt32)malloc(sizeof(ViUInt32));
 pHandle=GetActivePanel();
 Vpp=0;
 //(1) Initiate
 //tkds30xx_init ("GPIB0::1::INSTR", VI_TRUE, VI_TRUE, &DPOHandle);
 tkds30xx_InitWithOptions ("GPIB::1::INSTR", VI_TRUE, VI_TRUE,
  "Simulate=0,RangeCheck=1,QueryInstrStatus=1,Cache=1",&DPOHandle);
 //tkds30xx_ConfigureAcquisitionType (DPOHandle, TKDS30XX_VAL_NORMAL);
 //Delay(2);
 //(2) Config Channel
 tkds30xx_ConfigureChannel (DPOHandle, TKDS30XX_VAL_CH_1, 100, 0,
  TKDS30XX_VAL_AC, 1.0, VI_TRUE);
 //tkds30xx_ConfigureTrigger (DPOHandle, TKDS30XX_VAL_EDGE_TRIGGER, 0.0);
 //tkds30xx_ConfigureTriggerModifier (DPOHandle, TKDS30XX_VAL_NO_TRIGGER_MOD);
 //(3) Init Acquisition
 //Delay(2);
 MessagePopup("Information"," Initiate finished!");
 tkds30xx_AutoSetup (DPOHandle);
 MessagePopup("Information"," AutoSetup finished!");
 //goto CLOSE;
 //Delay(2);
 tkds30xx_InitiateAcquisition (DPOHandle);
 //tkds30xx_ConfigureInitiateContinuous (DPOHandle, VI_TRUE);
 //tkds30xx_ForceTrigger (DPOHandle);
 //MessagePopup("Information"," ForceTrigger finished!");
 //Delay(2);
 //(4) Fetch WaveForm Measurement
 MessagePopup("Information"," To Read Measurement...!");
 tkds30xx_FetchWaveformMeasurement (DPOHandle, TKDS30XX_VAL_CH_1,
  TKDS30XX_VAL_VOLTAGE_PEAK_TO_PEAK, &Vpp);
 //(3),(4)
 //MessagePopup("Information"," To Read Measurement...!");
 //tkds30xx_ReadWaveformMeasurement (DPOHandle, TKDS30XX_VAL_CH_1,
 // TKDS30XX_VAL_VOLTAGE_PEAK_TO_PEAK, 1000, &Vpp);
 MessagePopup("Information"," Read Measurement finished!");
 //(5) Display in numeric box
 SetCtrlVal(pHandle,tabTk_numVpp,Vpp);
 //MessagePopup("Information"," Connect Completely!");
CLOSE:
 //(6) Close
 tkds30xx_close (DPOHandle);
 MessagePopup("Information"," Close DPO connect!");
(3,070 Views)
Have you tried
 tkds30xx_ConfigureTriggerModifier (DPOHandle, TKDS30XX_VAL_AUTO);
or
//tkds30xx_ConfigureTrigger (DPOHandle, TKDS30XX_VAL_IMMEDIATE_TRIGGER, 0.0);
Regards
Ray Farmer
Regards
Ray Farmer
(3,055 Views)
