LabWindows/CVI
I can't set camera attribute using imgSetAttribute
I'm using Imaq for acquiring data from an Hamamatsu Flat Panel. Modifing the camera attributes using MAX Measurement & Automation Explorer i can correctly see the modifications using imgGetAttribute and imgGetCameraAttribute (Numeric and String) functions but using imgSetAttribute and imgSetCameraAttribute i can't modify attributes like framerate, binningmode and width and height of the image. Can someone tell me if there are particular procedures using these functions like file's permissions?
Thank You
(3,305 Views)
Hello israfel,
you can take a look at the document linked below for some useful informations:
Setting My Camera Attributes Programmatically Does Not Permanently Change the Attributes
Hope this can help you.
Andrea N.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(3,288 Views)
Thank you for the answer but there is any way to call the MAX's attribute interface during the execution of my LabWindows/CVI code?
(3,244 Views)
Hello israfel,
can you give more detail please?
What do you mean when you say "call the MAX's attribute interface during the execution... "?
If you mean calling the MAX interface from the CVI program, I don't think it's possible.
Andrea N.
Andrea N.
(3,225 Views)
