12-22-2009 02:39 AM
Dear,
Sir/Madam
I've a difficulty of using this command : OpenDocumentViewerInDefault which i can proper run in LW 8.5 version but no available in LV 5.5 toolbox.fp.
Any other replacement method for open the text file for view?
thank
12-22-2009 03:20 AM
12-22-2009 03:34 AM
You can enter the full path of the text file as in:
system ("notepad.exe c:\\mydocs\\Dec2009\\quote.txt");
You can also use LaunchExecutable function if you do not want to wait for the notepad to be closed, to continue your program execution.
Hope this helps,
