LabWindows/CVI
How to use LabWindows/CVI to integrate 3rd party application with the DAQmx and drivers to test on the analog/digital IO boards ?
I have a huge application written in C. I want to test that application with the digital and analog cards using drivers and DAQmx. The idea is to modify the existing application very little and integrating with DAQmx. Is that possible using LabWindows/CVI ? Or is there any other method which is advised.
(3,297 Views)
Hey Esha,
It is absoultely possible to do that in CVI.  To get you started, if you have installed CVI and support for DAQmx driver, you go to Help>>Find Examples and then navigate to Hardware Input and Output>>DAQmx there should be bunch of examples that can get you started also you more detail help on C API you can reffer to C Reference Help under Start>>All Programs>>National Instruments>>NI-DAQ>>Text based support.
NI-khil
(3,285 Views)
You can also go to http://www.ni.com/code/ for many more codes available online. You can also refer to Getting Started with LabWindows/CVI here.
(3,262 Views)
