LabWindows/CVI
How to use Excel_RangeFind(Next) ?
For my project I need to search an excel sheet and find which cells contains the text '###START'.
Off course I can search every cell in the sheet with two for-loops, one for column and one for the row,
I think it should be quicker to use the Excel_RangeFind and Excel_RangeFindNext functions.
I created the following code (removed the error handling for readability reasons)
// Get Active Workbook Sheets
Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppSheets, CAVT_OBJHANDLE, &ExcelSheetsHandle);
// Get Sheet by index
Excel_SheetsItem (ExcelSheetsHandle, NULL, CA_VariantInt(sheetIndex), &ExcelWorksheetHandle);
// Make Sheet Active
Excel_WorksheetActivate (ExcelWorksheetHandle, NULL);
CA_VariantSetCString (&MyVariant, "###START");
// Set Range to Sheet
CA_VariantSetCString (&MyCellRangeV, "A1:IU65536");
Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyCellRangeV, CA_DEFAULT_VAL, &ExcelRangeHandle);
Excel_RangeActivate (ExcelRangeHandle, &ErrorInfo, NULL);
Excel_RangeFind (ExcelRangeHandle, NULL, MyVariant, CA_DEFAULT_VAL, CA_DEFAULT_VAL,
CA_DEFAULT_VAL, CA_VariantInt(ExcelConst_xlByRows), ExcelConst_xlNext,
CA_DEFAULT_VAL, CA_DEFAULT_VAL, &FoundRangeHandle);
Excel_RangeAddress (FoundRangeHandle, NULL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, ExcelConst_xlA1, CA_DEFAULT_VAL, CA_DEFAULT_VAL, &ptr);
while (...)
   status = Excel_RangeFindNext (FoundRangeHandle, NULL, CA_DEFAULT_VAL, &FoundRangeHandle);
Problem with this code is that it is only finding the first field which contains '###START'.
I am using the excel2000.fp and Excel2010 with Labwindows/CVI 9.0.
Does someone has experience with the RangeFind functions ?
Thanks for helping, Patrick
(3,428 Views)
Are you based on the example of using Excel (excel2000dem). You select a range and you read, then you do your search. Really I have not used this function, but it seems to me that you must use the same principle.
(3,423 Views)
I think that you have to look at the links below. They could be useful.
http://www.cpearson.com/Excel/FindAll.aspx
http://excel.bigresource.com/-range-find-need-to-return-cell-address-DQfGFsOA.html
(3,400 Views)
Thanks for the links. I will try these when I am back from my current trip to Romania.
Regards
(3,398 Views)
