LabWindows/CVI
How to turn off silent mode when using compile.exe ?
I'd like to use the command line compiler and see what files/commands are involved.  Running compile.exe without options must be in silent mode because nothing is printed to the screen.  Is there an option to turn off silent mode?
(3,621 Views)
well, you could use -log logfile. This argument copies all build output to the logfile you specify.
(3,614 Views)
Wolfgang,
There isn't any output to be logged.  I'd like to see the files that are being compiled  . . . like when you type make and it prints the commands that are being run (for example).
Thanks!!
(3,607 Views)
Hi cooGal,
If you search "command line compiler" in the CVI help will show you all of the functionality.  Wolfgang has the best suggestion.
Have good one!
Dustin D
(3,584 Views)
