LabWindows/CVI
How to show part of data in row in a table in another table with same no column ?
I need to show  data of some rows in a table in another table with same nos of columns  and main table to be disabled. Could anyone hints how to do that ?    Data in table is coming from the microprocessor and purpose is user can see and modify only some data.
If anyone show me some hints it will be a great help.
Auntu
(3,623 Views)
If tables has exactly the same structure (i.e. number of columns and data type for each of them) the simplest way to pass data from one table to another is to pass by system clipbord using ClipboardPutTableVals and ClipboardGetTableVals
(3,620 Views)
Roberto,
Thank you for your reply. But how to disable the original table or how to hide it from the user  and again when require how to enable it ?
Regards.
(3,587 Views)
What are other ways instead of using clipboard.
Regards.
(3,586 Views)
Accepted by topic author auntu_dh
Disable a table: SetInputMode (panelHandle, controlID, 0);  ('1' to re-enable it).
Hiding a table: SetCtrlAttribute (panelHandle, controlID, ATTR_VISIBLE, 0); ('1' to show it again).
These commands are valid for each control types.
To extract values from the table you can simply use GetTableCellVal or GetTableCellRangeVals: if the range of cells has the same data type you can use the second command which is faster; if cells are different (e.g. numeric and strings) you must individually address each of them. Using the clipboard does not have this limitation.
(3,581 Views)
