LabWindows/CVI
How to set the time slice using CWGraph
Hi!
How can I set the time slice in CWGraph? It's not necessary to set it programatically, but I didn't find the place that I can set it in properties.
I want to fix the time slice of X axis in 3 minutes. If the data is 3 minutes old, it will not appear in the graph because the graph moves from right to left.
How can I fix or solve it?
I am using CVI 8.1 and Measurement Studio 8.1
I also attached the .uir file which I am trying to use.
Thank you in advance.
Gustavo
(3,347 Views)
Hi
If you remove the autoscale option for the x-axis and write 0 to 300. By that the x-axis will take 300 points
You will have to adjust the number based on the updating frequency. A rate of 100 updates pr. min.
will result in 3 minutes. This works for CWUIControlsLib__DCWGraphChartY()
There are several plot functions and I don't know if it will work with others.
Regards Per
(3,299 Views)
Is there any way to plot it if I don't know the data frequency previously?
Regards
(3,296 Views)
Hi
Not sure what you mean.
You can use CWUIControlsLib_CWPlotPlotXY () to plot an array of previously collected data.
(3,291 Views)
