LabWindows/CVI
How to return Record ID from an SQL write operation
I am currently using LabWindows/CVI Version 6.0 and SQL Toolkit version 2.0.6 and was wondering if there is any way to return the Record ID of a record which has just been created similar to the @@SELECT command in VB? At the moment I am writing the record and then having to do several operations which are taking a long time to complete, i.e.
DBAllowFetchAnyDirection
DBActivateSQL (SELECT * from Table)
DBNumberOfRecords
DBDeactivateSQL
DBBeginMap
DBMapColumnToInt (Record ID)
DBActivateMap
DBFetchRandom (Last Record)
DBDeactivateMap
I need this Record ID to cross reference a second table which contains results information.
(5,681 Views)
Hi Kacout,
Having looked at your query, I am wondering whether you could possibly post your code so I can have a look at it? I'm not sure offhand whther there is such a method directly available, and I have a feeling that the long winded process you mentioned may be the only way. but I will happily have a look into this further for you.I would just be easier to have a look at your code so I can grasp more solidly the purpose of your program.
Best wishes
Rob L
NI Applications Engineer
UK & Ireland
It only takes a click to rate this message 😉
(5,646 Views)
Thanks for getting back to me - can you please supply email address and I will send code to you.
(5,641 Views)
Hi Kacout,
If you are able to provide me a with an email address, I can send you an email which you will be able to reply on.
Best wishes
Rob L
UK & Ireland
(5,634 Views)
Email address is kenneth.coutts@raytheon.co.uk.
Regards.
(5,633 Views)
Hi Kacout,
My apologies that I have not been in touch for a while, it's been a bit crazy here and I've been having significant problems installing the SQL toolkit for CVI. I am still in the process of looking for a specific SELECT command equivalent to that found in VB, and will let you know when I do. In the mean time, I have developed the code below which I'm wondering might be of use to you. not sure if the syntax is completely correct, but I think you might be able to use it.
DBActivateSQL(SELECT[RECORD ID]FromTable.*SortBy[RECORD ID]Descending)
DBFetchRandom(FirstRecord)
Not sure if this will greatly increase the speed of your operation ( I think the main thing slowing it down is activating the Table into memory) but let me know if this is of any use. I could be on completely the wrong track.
Best wishes, I will be back in touch ASAP.
Rob L
UK & Ireland
(5,565 Views)
