11-17-2008 05:06 AM
Hi All!
I a ring control whose label/value entries depends on the content of another ring. What I do is a switch on the content of the "master" ring and a sequence of InsertListItem on the "slave" ring.
However, I am not able to delete the entries that I have added when I switch to another label/value subset.
So my question is: is there a command to remove/eliminate label/value entries from a ring?
Thank you very much for the help
Francesco
11-17-2008 05:35 AM
11-17-2008 05:39 AM
Wow it work!!!
great!
Thanks Roberto!!
Francesco
11-17-2008 05:43 AM
Hi Roberto!
since the number of items is not constant, is there a way to retrieve the total number contained in the control?
Thanks again
Francesco
11-17-2008 06:02 AM
Ok this one I dicovered it by myself 🙂
numberOfItems = -1
to remove all the entries.
Thanks again
11-17-2008 07:27 AM
