LabWindows/CVI
取消
顯示結果
搜尋替代
您的意思是:
How to read back CAN session Arbitration ID from NI PCI-8513 XNET database
I am using NI CAN controller PCI-8513 with XNET database. Database setup can be seen in the picture below
I am able to read CAN  session name by using the following code in LabWindows CVI.
When returned, PropList = "PID_Write_ECU1". Now I want to get the arbitration ID (0x712). How can it be done? Help please
uint32_t propertySize;
uint8_t PropList[100];
uint8_t DatabaseName[100];
nxDatabaseRef_t DatabaseRef;
uint32_t ArbID;
nxStatus_t nx_status;
char CAN_DB_FilePath[100] = "C:\\temp\\XNET_Database.xml";
nx_status = nxCreateSession (CAN_DB_FilePath, "CANA", "PID_Write_ECU1","CAN1", nxMode_FrameOutSinglePoint, &PID_Write_ECU1); // 0x712
nxGetPropertySize (PID_Write_ECU1, nxPropSession_List, &propertySize);
nxGetProperty(PID_Write_ECU1, nxPropSession_List, propertySize, PropList);
nx_status = nxClear (PID_Write_ECU1);
0 積分
1 條訊息(共 5 條)
2,950 檢視
After looking at the documentation it seems to me that that value cannot be retrieved from the session but it must be read from the database you are using instead,  by means of the function
nxdbGetProperty (DbObjectRef, nxPropFrm_ID, 0, &PropertyValue);
Look at these help pages: nxdbGetProperty  and nxPropFrm_ID
0 積分
2 條訊息(共 5 條)
2,929 檢視
I've tried the function of nxdbGetProperty before, but failed.
nxdbOpenDatabase (CAN_DB_FilePath, &DatabaseRef);
nxdbGetProperty(DatabaseRef, nxPropFrm_ID, 4, &ArbID);
0 積分
3 條訊息(共 5 條)
2,907 檢視
Hi Charlie,
Since you are using the nxdbOpenDatabase function to immediately store the database reference in DatabaseRef, I have to assume one of the other references in nxdbGetProperty are causing this error to be thrown. Are you sure nxPropFrm_ID is a valid u32? I would just double check all the parameters you're passing to it with this help document on the function: http://zone.ni.com/reference/en-XX/help/372841T-01/nixnet/nxdbgetproperty/
Applications Engineering
0 積分
4 條訊息(共 5 條)
2,897 檢視
Disclaimer: I never tried to get this property so I may be wrong
In my opinion the idea to focus on is to use the correct object reference: since you are looking for a frame attribute, you should pass a frame object reference, which I suppose you can obtain by calling
nxdbFindObject (ParentObjectRef, nxClass_Frame, "", &DbObjectRef);
with the appropriate parameters (e.g. the frame name). As far as I can understand, the parent object reference should be the database reference you have already gotten.
0 積分
5 條訊息(共 5 條)
2,890 檢視
