LabWindows/CVI
How to programmatically launch a debuggable exe for CVI debugging.
I'm launching an executable from another CVI app. I want to debug the one I'm launching, AND pass arguments to it.
Using something like "cvi -run_then_exit myProcess.prj" doesn't provide for args unless they are hard coded into the project's CommandLine option.
Running 'cvi -p' is too late to catch initialization.
Are there options I haven't found yet?
(CVI 5.5.1 on NT)
(2,982 Views)
You should use CVI's ActiveX server. Go to the cvi\samples\activex\cvi\cvidemo.prj to see an example of how to use this. From here you can Launch CVI, Load Project, Compile and Run them, etc. There is also a function to SetCommandLine that will let you programmatically change the command line settings for the project.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(2,982 Views)
