LabWindows/CVI
How to make a Veristand model with LabWindows CVI
Hello community,
I am kind of new to LabWindows / CVI and searching for a way to make a Veristand 2010 model using LabWindows/CVI  2010 since yesterday.  Without any usable results within the Veristand & CVI help, examples and this forum. All I found out is, that i have to generate an DLL, ok, but how do I define the Veristand inports, parameters and Outports? Is this generally possible to do that without utilizing Simulink or LabView or anything else except Veristand and CVI? Is there maybe a tutorial i just have not found?
For example: I want to generate a finite pulse train with a user defined frequency and a number of pulses on my PXI 6608. For that i found a good example in CVI, which works just fine. I would like to have both of the variables as Inports when I create the model for Veristand. In LabView that was done very easily using the connector pane. But in CVI i just can't find out.
Thank You
Kind regards
Philipp
(3,747 Views)
Hi Philipp,
there is a Veristand Model Framework making it possible to integrate model dlls into Veristand.
It is described in the attached document.
Marco Brauner NIG
(3,711 Views)
Philipp,
when you install NI VeriStand 2010, make sure that the option 'Install Model Framework' is checked in the customized installation settings.
This flag will create the C:\VeriStand folder.
You will find the PDF (that Marco has posted) along with some examples at this location: C:\VeriStand\2010\ModelInterface\custom
Tom
(3,707 Views)
