LabWindows/CVI
How to kill/terminate other programm?
I want to make program kill other program which is running. For example, if the notepad.exe program is running now and I want to destroy or kill this program using CVI. How do I do?
(3,127 Views)
Hello
You'll probably need to use the Windows SDK for this. It gets installed with CVI, just not by default. Check out this link on how to terminate an application cleanly. Also check out the TerminateProcess() function in the SDK
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,127 Views)
