LabWindows/CVI
How to identify Lab Windows/CVI Run Time Engine version programmatically?
Is there a way to identify the version of installed Lab Windows/CVI Run time engine through a separate program like searching registry or some other method?
(3,623 Views)
A running CVI program can query the run-time engine version by using GetCVIVersion function. Othervise you can query the version of cvirte.dll, usually located in \windows\system32, unless it is installed elsewere.
(3,613 Views)
