LabWindows/CVI
How to get an event signal triggerd by TIMER (under user inferface) by using GetUserEvent()
I want to use GetUserEvent() inside a loop for polling TIMER event, instead of using RunUserInterface() and TIMER calllback function.
but it seems GetUserEvent() can't get TIMER event. Are there any thing that I should notice before using GetUserEvent()?
I use a command button(PANEL_Add) to switch TIMER ON/OFF, the time interval is 1 second and TIMER is initially OFF.
PANEL_LED shows the status of TIMER ON/OFF flag.
PANEL_LED did turn on/off after I click the command button, but the counter value didn't change anyway while TIMER is enabled.
Thanks for answering~
Here is my code
int main (int argc, char *argv[])
    int error = 0;
    int done  = FALSE;
    int eventPanel;
    int eventCtrl;
    int panelHandle;
    unsigned int Count=0;
    int flag=0;
    /* initialize and load resources */
    if (InitCVIRTE (0, argv, 0) == 0)
        return -1;
    if ((panelHandle = LoadPanel (0, "Timer.uir", PANEL)) <= 0)
        return -1;
    /* display the panel and run the user interface */
   DisplayPanel (panelHandle);
   while (done == FALSE){
         GetUserEvent (1, &eventPanel, &eventCtrl);
         switch (eventCtrl){
                case PANEL_Add : flag = (flag==TRUE)? FALSE:TRUE;
                                            SetCtrlAttribute (panelHandle, PANEL_TIMER, ATTR_ENABLED, flag);
                                            SetCtrlVal(panelHandle, PANEL_LED, flag);
                                            break;
                case PANEL_TIMER : SetCtrlVal(panelHandle, PANEL_Counter, Count++);
                                                if(Count > 19)
                                                       Count = 0;
                                                break;
     /* clean up */
    DiscardPanel (panelHandle);
    CloseCVIRTE ();
    return 0;
and here is the .h file
#include <userint.h>
#ifdef __cplusplus
    extern "C" {
#endif
#define  PANEL                            1
#define  PANEL_Counter              2
#define  PANEL_Add                    3
#define  PANEL_LED                    4
#define  PANEL_TIMER                 5
#ifdef __cplusplus
#endif
(4,454 Views)
Accepted by topic author morphous
according to the help GetUserEvent obtains the next commit event or programmer-defined event from the GetUserEvent queue. A commit event occurs when the user changes the state of a hot or validate control or selects a menu item.
Place programmer-defined events in the GetUserEvent queue by calling QueueUserEvent.
Because the timer does not generate a commit event, you need to call QueueUserEvent; for this you will need to use the TimerCallback function that you didn't like... I see no other way than using the callback function of the timer
Message Edited by Wolfgang on 03-19-2010 09:40 AM
(4,450 Views)
Thanks for answering~~
But this lead me to another question.
For testing QueueUserEvent(), I have modified my code and now it look likes the following
#define MyEvent1 1001
inside TIMER callback function
switch (event)
    case EVENT_TIMER_TICK:  QueueUserEvent(MyEvent1, panelHandle, PANEL_TIMER);
                                             break;
 return 0;
and now the polling loop becomes
switch (eventCtrl){
                                                        break;
                            case MyEvent1 :   SetCtrlVal(panelHandle, PANEL_Counter, Count++);
                                                        if(Count > 19)
                                                               Count = 0;
                                                        break;
what I thought is this should insert a new event into queue everytime after TIMER callback been executed,
and GetUserEvent() shold be able to get the event in polling loop.
But it didn't.
Did I miss anything again?
(4,441 Views)
I don't think that this is the most straightforward solution.... Why don't you put your statement into the timer callback, i.e.
switch (event)
        if(Count > 19) Count = 0;
    break;
This makes life much more simple 🙂
Message Edited by Wolfgang on 03-19-2010 11:01 AM
(4,435 Views)
yes, you are right
the code you post is the exact code I wrote at the first place~
To be curious, I just want to test how to use QueueUserEvent()  but nothing else. Smiley Tongue
(4,430 Views)
ok, in this case you need tp check the event status by using event_status = GetUserEvent (1,.. ,.. ) ...
from the help:
The event, if any, that occurred.
0No event.
1Commit event occurred.
1,000-10,000Event queued by QueueUserEvent.
(4,423 Views)
Be warned: if your panel has a menu bar your program will stay inside GetUserEvent() if the mouse cursor is sitting on a menu or menu item until the mouse is moved away or a menu item has been selected
(stupid tracking loop) .
/* Nothing past this point should fail if the code is working as intended */
(4,413 Views)
