LabWindows/CVI
How to dynamically call DLLs in CVI
    I'm thinking of an application CVI. I have several DLLs(including .h file) under a folder and in future more DLLs will be put into that folder as an extension application/plug. These DLLs have the same input and output format. A UIR based exe application built in CVI will call certain DLL under that folder according to the value of a control on that UIR. I don't know how to have that function in CVI,that is to say,how to dynamically call DLLs in CVI?  An example is prefered.
    Currently, the problem I encountered is if I want to call an external DLL, I have to include its .lib and .h file in project. However, what I would like to see is I can call DLL without including its lib and .h file in project.
Thanks!
Jacky
(3,185 Views)
You could use the combination of LoadLibrary(), GetProcAddress() and FreeLibrary() SDK functions.
JR
(3,174 Views)
More information on how to access dlls from CVI can be found here
http://zone.ni.com/devzone/conceptd.nsf/webmain/1d0c73348d50de5486256faf00614757?OpenDocument
and here
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6BaSAK&l=en-US
Message Edited by mvr on 05-04-2006 11:09 AM
(3,167 Views)
