LabWindows/CVI
How to delete or rename a file with lab windows 3.1?
Hi, I'm working with Lab windows 3.1 and I want to delete and rename a file. How cand i do that.
for exemple: delete c:\Test
and rename c:\New -> c:\Test
tanks
David
(3,007 Views)
LabWindows 3.1 and later versions give you DeleteFile() and RenameFile() functions. To select them (or other related file functions), in a code window, use the Library menu: select Library >> Util >> File Utilities >> DeleteFile or RenameFile. The function panels will open and you'll be open to enter your parameters (variable names or quoted string constants) and insert the function call.
Al
(3,007 Views)
