LabWindows/CVI
How to control TS Operator Interface
How can I control TestStand Operator Interface from CVI?
I'd like to move the TestStand Operator interface to one side of the
screen so that my CVI program can display its own panle on the rest of
the area.
How do you do that?
How can you maximize the TS panel?
Rafi
(3,230 Views)
Rafi,
If your are using the TestStand Operator Interface (OI) written in
CVI, you can use the SetPanelPos function to change the position of
the OI panel programmatically.
With the SetPanelAttribute function you can set whether the panel can
be minimized or maximized, but to actually minimize or maximize a
window programmatically you'll probably need to use a Windows API
function.
Matt P.
(3,230 Views)
Thank you Matt,
1) position - I found it eventually and used 2 setAttribute functions
to achieve the same. The function you suggested is better and I used
it instead.
2) max/min - Where do I find Windows API? It is not listed in the
library. Is it some sort of ActiveX I need to install?
Rafi
"Matt P." wrote in message news:<506500000005000000345C0100-1075935269000@exchange.ni.com>...
> Rafi,
> function.
> Matt P.
> National Instruments
(3,230 Views)
Rafi,
Windows API is a Microsoft tool.
I believe the function you will want to use is the 'ShowWindow'
function:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/winui/WinUI/WindowsUserInterface/Windowing/Windows/WindowReference/WindowFunctions/ShowWindow.asp
You'll see from the above web page that the ShowWindow function is in
the user32 library, which should be found under C:\WINDOWS\system32 in
a DLL form.
I hope that helps.
Best Regards,
Matt P.
(3,230 Views)
