LabWindows/CVI
How to configure syntax error
Hello Guys,
Please help me configure this error. Below is the code.
/*****************************FAIL Bit**********************************************/
void FailBoard (int x)
 char str[5];
 long i;
 if (GetBitFestoInputs(3,1)
  GetCtrlVal(panelHandle_Cobot, PANEL_esFail, str);
  i = atol(str);
  i++;
  sprintf(str, "%lu", i);
  SetCtrlVal(panelHandle_Cobot, PANEL_esFail, str);
 return;
I got an error syntax error: found '{'expecting')'
Thanks in advance.
(3,493 Views)
Accepted by topic author Master_Viper
Hi Master_Viper,
the error message is quite clear: a closing parenthesis is missing; the complete message should list also list line and position of the error, which could help you to locate and solve it by yourself.
In any case, if the code is the one you posted the error should be this one (missing parenthesis highlighted in red):
 if (GetBitFestoInputs(3,1))
(3,476 Views)
Sir Roberto,
Can I ask another question but different topic or do I need to create new topic.
Master_Viper
(3,465 Views)
If the new question has no relation with this topic it is better to open a new discussion.
(3,390 Views)
