LabWindows/CVI
How to change a batch of file's extension
Hello all,
I want to write a program whose function is to change the extensions of a batch of files.for example,change all the files with the .prn extension to .csv or .xls extension.How can i realize it?i'm using LV7.1.
(3,594 Views)
Hi ldragon, you've accidentally posted this questino to the CVI forum. You should repost it to the LabVIEW forum wher you will find several experienced users that can help you.
(3,583 Views)
Hi Roberto,you're right.I should have posted this question to Labview forum.but i have already solved the problem by myself.Thank you all the same!
(3,556 Views)
