LabWindows/CVI
How might I implement a rotary encoder knob?
Hi all,
I am currently using the 6.0 version, is there a work-around to use mouse-wheel-scrolls?
-T.
Message 11 of 14
(1,365 Views)
Hello TurboMetrologist,
I am not sure if there is a workaround for CVI 6 since this is no longer support and the UIR changed formats in CVI 7.1. You can take a look at the code and try and implement it in CVI 6 by creating a new UIR, though some commands may not be available in CVI 6 that are used in a later version. Have a great day!
Best Regards,
Adam G
Message 12 of 14
(1,324 Views)
Turbo:
CVI 6.0 doesn't have built-in support for the mouse wheel, but you can use InstallWinMsgCallback () to capture Windows message WM_MOUSEWHEEL.
Look at the attached sample (developed in CVI 6.0), which just has a numeric dial which can be controlled by the mouse wheel.
This sample is based on several I found on the forum and on the toolbox sample that shipped with CVI 6.0, ..\CVI\samples\toolbox\msgdemo.prj
Message 13 of 14
(1,266 Views)
Thanks! That was an excellent example.
Message 14 of 14
(1,228 Views)
