LabWindows/CVI
How do you detect wheather release or debug build.
I want to detect in my code is the code running in the release or debug mode. is there any inbuil function like in labview there is property node called application.kind to get the status of the code.
(5,226 Views)
You could use the macro _CVI_DEBUG_ which is defined as 1 in debug configuration, see the help section on 'Predefined Macros'
(5,221 Views)
This macro will not work if the build configuration is release mode, it can be used only for debug mode.
While building in release mode the CVI will throw an error saying undefined symbol "_CVI_DEBUG_"
(5,217 Views)
Thanks for your valuable reply..
Actually this is working only in debug configuration but in release configuration it is giving undefined symbol.
can you please help me in detail.
(5,216 Views)
So continue reading here Smiley Wink
(5,210 Views)
(5,205 Views)
There additionally is the function BeingDebuggedByCVI ()
(5,200 Views)
