LabWindows/CVI
How do I use ZLIB in LabWindows?
I downloaded the ZLIB 1.2.5 DLL from zlib.net and I am trying to use it with a C program for LabWindows 8.5.  I copied the DLL into my windows\system32 folder and the .h/.lib files into my project.  When I try to build my code, I get an error that sys/types.h was not found.  (zconf.h is trying to include this file.  It does not exist in my LabWindows installation.)  From previous posts, I know that other users have been able to build ZLIB using LabWindows.  How do I do it?
Rich Ferrara
(3,990 Views)
Accepted by topic author richferrara
Rich:
types.h is commonly defined in unix systems.  I'd suggest you start by commenting out line 364 in zconf.h and see what other errors you get.
Lines 363 through 365:
#ifdef STDC
#  include <sys/types.h>    /* for off_t */
#endif
The comment on line 364 says that types.h is included for off_t.
Here's a link from IBM that describes the contents of types.h
http://publib.boulder.ibm.com/infocenter/aix/v6r1/index.jsp?topic=/com.ibm.aix.files/doc/aixfiles/ty...
It describes off_t as follows.
off_t File offset, measured in bytes from the beginning of a file or device. off_t is normally defined as a signed, 32-bit integer. In the programming environment which enables large files, off_t is defined to be a signed, 64-bit integer.
If you comment out line 364 and get errors regarding off_t, define it yourself, using the default int size on your system.
typedef int off_t;
(3,982 Views)
Thanks, it looks like that worked.
(3,978 Views)
