LabWindows/CVI
How do I use InstallCtrlCallback with a class member function in Visual C 6.0?
I'm using Visual C++ 6.0.
I have a class definition with the following private member function declaration.
private:
int CVICALLBACK commandRoll(int panel,
int control,
int event,
void *callbackData,
int eventData1,
int eventData2);
Within another member function of the same class, I'm trying to call:
status = InstallCtrlCallback (itcsHandle,
ITCSGui_rollProp,
commandRoll, &callbackData);
I get following compiler error:
error C2664: 'InstallCtrlCallback' : cannot convert parameter 3 from 'int (int,int,in
t,void *,int,int)' to 'int (__cdecl *)(int,int,int,void *,int,int)'
None of the functions with this name in scope match the target type.
(3,265 Views)
You will most probably get this question answered at the Develope Studio Forum.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,265 Views)
Hello
I believe the callback member function needs to be static. Check out this article for more information.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,265 Views)
