LabWindows/CVI
How do I save the buffer data to the specilized file?
Help!
A portion of codes as follows:
double *pData;
double *pDataBuffer;
UINT length=1024;
pDataBuffer=GlobalAlloc(GHND,length);
pData=pDataBuffer;
When I have acquired amount of data,which have been saved to buffer whose pointer is pDataBuffer,but I can't save the data to the file,why?
Can you give me special material or code?
Thank you!
(3,087 Views)
Normally the fastest way to produce a file out of your data is the use of ArrayToFile function. You can document on the function in the online help which is fully detailed.
(3,076 Views)
