LabWindows/CVI
How do I hide the dos prompt window when running a command line via cvi?
Thank You
Arik Lewin
(4,091 Views)
Try using the 'Launch Executable Extended' function in the utility library. This gives you the option of running exe's in different modes, including hidden
(4,091 Views)
I used this function in windows 2000 an it works. It does not work with windows 98. Any Ideas how I can get it to work on windows 98 OS?
Thank You
Arik
(4,091 Views)
What exactly is the problem you are having? I use NT myself, but I had a quick play on a 98 machine, and it appeared to work the same
(4,091 Views)
Hi. Sorry for not being clearer in the previous question. the problem I am having with this function (LaunchExecutableEx)is that on win98 the "LE_HIDE" property does not work. Some of the other properties however do work eg "LE_SHOWMINNOACTIVE". I can minimize the dos prompt window but not hide it on the win98 OS. Thanks for the help thus far.
(4,091 Views)
Hi Arik,
Sorry, but I still can't duplicate your problem... I tried running an exe on a 98 machine using the hidden attribute, and it appeared to work fine (valid handle, no error) Obviously I couldn't see it, and as there is no useful task manager in 98, it's difficult to prove that it's working.
I did, however run a batch file in hidden mode, and that did appear to operate correctly...
You can send me your code if you like to see if I can duplicate your problem
Regards
JB
(4,091 Views)
