LabWindows/CVI
How do I get the sequence context from TestStand API?
I am trying to terminate an execution by clicking a button in CVI. Just a simple button, but I don't know how to get the SequenceContext. Here is what I have:
int CVICALLBACK TerminateButton (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 switch (event)
  case EVENT_COMMIT:
   CAObjHandle seqContext;
   TSObj_Execution excObj;
   ERRORINFO errorInfo = { 0, 0, "", "", "", 0, 0 };
   ErrMsg errMsg = "";
   int error = 0;
   tsErrChk(TS_SeqContextGetExecution (seqContext, NULL, &excObj));
   tsErrChk(TS_EngineTerminateAll (seqContext, NULL));
   QuitUserInterface(0);
   break;
Error:
  return 0;
(3,942 Views)
I am not sure how you are getting to the TestStand Engine.  Did you place an ActiveX control object from the TestStand Engine Class, or lanch testand using TS_NewEngine which gives you a Handle to the TestStand Engine.  You want to use that in your call to TS_EngineTerminateAll.
ex
     CAObjHandle engineObj = 0;
      ERRORINFO   errorInfo;
     TS_NewEngine(NULL, &engineObj);   // Creating new instance of TestStand
   TS_EngineTerminateAll(engineObj, &errorInfo);
If you placed an ActiveX control on a panel in your uir, you can get the handle by the following:
 GetObjHandleFromActiveXCtrl(panel,  PNL_ENGINE_CTRL,  &engineObj )
// panel is a handle to the panel
// PNL_ENGINE_CTRL is the control ENGINE_CTRL on panel PNL.
Hope this helps.
Mike
(3,936 Views)
