10-26-2012 01:05 AM
I m new to this Forum.
I m making a data logger and the data's are plotted in a Graph.The graph would have 100thousand point and would have around 64 different plots.For offline analysis, I store the entire panel using SavePanelSate().This methode I use to store like a database.
And then once I recall the panel suing RecallPanelState(), I would like to Zoom, Scroll,Hide, Change the line type and Change the color of plots.
I can achive Zoom, Scroll but unable to Hide or change the color plot when the Graph is already plotted.
My question here is:
1) Can get the Graph plots to arrays ? so that I can replot..
2) If not then Is ther any way to change the plot colors or Hide, UnHide once plotted..
Hope I get some tricks here...
Thanx
Bala
10-26-2012 01:11 AM - edited 10-26-2012 01:20 AM
Hi Bala,
certainly you get some assistance here ![]()
You also should have a look at the examples provided with CVI. For example, graphs.cws shows how to change the color of a plot...
In general, the function SetPlotAttribute (, , , ATTR_TRACE_COLOR, ); SetPlotAttribute (, , , ATTR_PLOT_STYLE, );, etc. will be useful for such purpose.
What is important is to have the 'Data mode' set to 'retain' and the 'Copy original plot data' checked.
10-26-2012 01:58 AM
In case you want to retrieve plot data, you can use GetPlotAttribute function with the attributes
ATTR_PLOT_XDATA, ATTR_PLOT_XDATA_TYPE and ATTR_PLOT_XDATA_SIZE for the X axis and ATTR_PLOT_YDATA, ATTR_PLOT_YDATA_TYPE and ATTR_PLOT_YDATA_SIZE for the Y axis.
All Set/GetPlotAttribute functions neet for you to supply the plot handle, which you may need to store somewhere to retain the correct association between data/plots and actual trend recorded.
