LabWindows/CVI
How do I find out if Text in a Cell in Excel has strikethrough Font?
I'm reading in an excel spreadsheet and reading in the text from the required cells. I want to skip any cells where the text has been striked (struck?) through.
I've tried using the code:
error = Excel_GetProperty (ExcelSingleCellRangeHandle, &ErrorInfo, Excel_FontStrikethrough, CAVT_OBJHANDLE, &MyHandle);
but this didn't work.
Any suggestion?
Thanks.
 Neil.
(3,359 Views)
Accepted by topic author Regenersis
Hi Neil,
If you use          ExcelRpt_GetCellRangeAttribute (CAObjHandle worksheetHandle, char cellRange[], int attributeID, void *attributeValue)
and use if...else with the following properties          ExRConst_False     (Boolean False)          and          ExRConst_True     (Boolean True)
You then should be able to manipulate as necessary.
Help with these functions can be found in the NI Labwidows/CVI Help under Tools Library>>Excel Report>>Alphabetical List of Functions and highlighting the ExcelRpt_GetCellRangeAttribute function.
Hope this helps
Steve H
National Instruments UK
(3,340 Views)
