LabWindows/CVI
How do I do Error trapping..
I have inherited a large CVI project that has almost no error handling. I know there are these IVI macros that allow me to encapsulate a function call, so that when/if an error is thrown in the function I can log that error to a file (or whatever).
Has anyone done something like this? I basically want to capture any errors that are thrown without having to add a bunch of extra code to the project. How do I go about implementing it?
Kindest,
Warren
(3,390 Views)
For an example of error trapping macros you can look at errChk and NullChk macros defined in the programmer's toolbox of CVI (look into \toolslib\toolbox\toolbox.h): these macros detect an error code as a return code for a function and jump to an Error label that you must define in your code.
I have used them and found useful for example when reading parameters file (I use .INI files for them). Here an example of use:
int error = 0;
IniText T = 0;
nullChk (T = Ini_New (0));
errChk (Ini_ReadFromFile (T, "application.par"));
errChk (Ini_GetInt (T, section, item, &val));
Error:
if (T) Ini_Dispose (T);
if (error < 0) {
// Here put your error managing code
return error;
Roberto
(3,390 Views)
