LabWindows/CVI
How do I access Hyper Access with active X using Labwindows/CVI 7.1 ?
I need help how to create a CVI program in Labwindows 7.1 to use HyperACCESS with Active X control. I did go through HyperACCESS API example program but none of those example for C (VBScript, Java and VBA only).  Thanks you
(4,018 Views)
Here are some threads that may be useful:
https://forums.ni.com/t5/LabWindows-CVI/how-to-use-ActiveX-Server/m-p/135630
Knowledge base:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000fzikSAA&l=en-US
Tutorial:
http://zone.ni.com/devzone/conceptd.nsf/webmain/b9b593ecbf7484be86256d10007651df
More reading:
https://forums.ni.com/t5/LabWindows-CVI/ActiveX-call-a-function/m-p/370841
Hope these help.
JLV
(4,016 Views)
Thanks you Joe. I found the thread from Dennis Knutson he has the program using Labview to access HyperACCESS ,I wish he can help me to convert the program to Labwindows/CVI. Because I don't know how to contact him. Would you show me how to contact with Dennis Knutson ?
(4,006 Views)
One simple trick is to reply to the same thread that was answered by Dennis, in the Labview forum.  He is very active in the forum and will most likely see the reply.
I will search that one (from LV) and see what needs to be done in cvi.
(4,001 Views)
Thanks you Joe, you can search in LV keyword : "Hyper Terminal" then you will see that thread.
(3,998 Views)
Actually, I am curious.
Why not simply write serial communication routines in CVI?  I find this much better than using HyperTerminal..
(3,992 Views)
I am using Hyper Access to communicate with flash sending command character and capture a response from flash to see it is function, also i need control the flash to do transmit signal and mean time i can use spectrum analyzer to read the power and sidelobe (NI GPIB) then store all readings to Excel format (I am OK using Active X with Excel). Hyper Access better than Hyper Terminal because i can use VBScript to write macro. My project is convert manual functional test (RF) to automated functional test.
(3,988 Views)
