LabWindows/CVI
How can you write a time interval into the User Interface Timer?
Using a Timer on a control panel, which triggers a callback function to sample data.  I'd like to read a numeric input from the user interface panel, and then set that value as the Timer interval.  But how do you write to the Timer interval?  The obvious function does not seem to work,
  SetCtrlVal (panelHandle, PANEL_TIMER, SampleSeconds);
(4,030 Views)
Hello -
You'll want to use SetCtrlAttribute:
SetCtrlAttribute (panelHandle, PANEL_TIMER, ATTR_INTERVAL, SampleSeconds);
NickB
(4,026 Views)
Excellent!  Can you direct me to a reference that shows the various attributes associated with functions?  I see that I can scroll the drop-down box in the function panel, but it has every parameter for every function, not just those pertaining, for example, to a Timer.  Thanks again.
(4,024 Views)
Accepted by topic author Sandia_Mike
Probably the best place to start is with the top level help for the control you're interested in.   I usually just go to the index tab in the help, start typing the name of the control (timer in this case) and then pick the top level help topic.  From here, you can see the attributes you can use, the events you can capture, programming concepts, etc.
NickB
(4,022 Views)
