LabWindows/CVI
How can I send a pulse to a RTSI line with a software command?
I need to generate a pulse to a RTSI line with a software command? How can I do this? I use a E Series
device.
(3,065 Views)
Hello
One way to do this would be to generate a single pulse using one of the counters on your e-series device( check out the daq examples under CVI for that) and you can use the Select_Signal() function to route the output of the counter to whatever RTSI pin you desire. Check out the help for Select_Signal() for more information.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,065 Views)
The examples that come with CVI may not do exactly what you want. NI's site has
an example called "Finite Pulstrain (DAQ-STC).zip", that does what you ask but
its for LabView only. The attached CVI project I wrote contains a lot of stuff
you don't need but one module (endotox.c) has the routines (PulseMode,
PulseTrainOn) you're looking for.
"giuliano.manfredini" wrote in message
news:5065000000080000004A660000-1031838699000@exchange.ni.com...
> device.
[Attachment endotox.zip, see below]
(3,065 Views)
