LabWindows/CVI
How can I pass a dynamic 2D array from a function which gets values from excel
I would like to pass a dynamic 2D array from a function. The function gets values from a range in excel. The function is based on exceldemo2000. Should I use safearrays? If yes how?
(2,984 Views)
Hello
Have you tried the CA_SafeArrayTo2DArrayBufEx(). The CVI ActiveX library has a variety of functions that let you manipulate various activex types as C types. You can check out the function help for more information about the functions parameters.
Bilal Durrani
NI
Bilal Durrani
NI
(2,984 Views)
