LabWindows/CVI
How can I get the directory(or folder) name?
Hello. I want to get directory name using Labwindows CVI. For example, my 😧 drive has 'aaa', 'bbb', 'ccc' directory(or folder),
and I want to get the directory name in specific folder using some function? Is there any function knowing the dirctory name?
(6,133 Views)
Please take a look at the function named "GetDir". This function gets the current working directory.
Also, the function "GetProjectDir" function gives you the directory in which the current project is present.
You may go to LabWindows/CVI help and search for all the functions related to dir or folder and see which one suits you the most.
Sastry, V.
National Instrumentsto
(6,133 Views)
Old question, but still relevant.
I have the same question, but have not found the solution. E.g. when connecting an USB memory stick it will appear with a name, often when new, brand name of the USB memory. I want to look for a specific name.
I can’t find this with GetDir()
Gerhard
Message Edited by *Gerhard* on 06-14-2010 04:27 AM
(5,651 Views)
I'm not sure if you can get this information using a CVI library function, but you can certainly use the Windows API function GetVolumeInformation().
Martin
Certified CVI Developer
(5,646 Views)
Yes !
Thanks,  it worked !
Gerhard
Code:
______________________________________________________________________
int CVICALLBACK FindUSB (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
    int Loop, Result, CurrentDrv, NumberOfDrv;
    char DirName[MAX_PATHNAME_LEN];
    char  lpVolumeNameBuffer[MAX_PATHNAME_LEN];
    char  lpVolumeSerialNumber[MAX_PATHNAME_LEN];
    char  lpFileSystemNameBuffer[MAX_PATHNAME_LEN];
    switch (event)
        case EVENT_COMMIT:
            for (Loop = 0; Loop <= 25; Loop++)
                Result = SetDrive (Loop);
                printf("SetDrive %2d / %c: %d", Loop, (char) (Loop + 65), Result);
                if (!Result)
                    Result = GetDrive (&CurrentDrv, &NumberOfDrv);
                    printf("   GetDrive %c: %d  %d", (char) (CurrentDrv + 65), NumberOfDrv,  Result);
                    Result = GetDir (DirName);
                    if (!Result)
                        printf("   Dir: %s", DirName);
                        GetVolumeInformation(    NULL,                                // lpRootPathName,
        lpVolumeNameBuffer,        // lpVolumeNameBuffer,
        300,                                 // nVolumeNameSize,
        NULL,                               // lpVolumeSerialNumber,
        NULL,                               // lpMaximumComponentLength
        NULL,                               // lpFileSystemFlags,
        lpFileSystemNameBuffer,  // lpFileSystemNameBuffer,
        300);                              // nFileSystemNameSize)
                        printf("   VolumeName: %s", lpVolumeNameBuffer);
                printf("\n");
         break;
    return 0;
(5,634 Views)
